[Qgis-developer] problem with debian/ubuntu daily builds
Bas Couwenberg sebastic at xs4all.nl
Tue Feb 9 02:13:19 PST 2016
On 2016-02-09 10:56, Martin Landa wrote:
> 2016-02-09 10:49 GMT+01:00 Bas Couwenberg <sebastic at xs4all.nl>:
>> Remove the old packages first, then install the new packages again.
>> There
>> won't be any old packags install to conflict with during the upgrade.
> I already tried that:
> sudo apt-get remove `dpkg --get-selections | grep qgis | cut -d' ' -f1
> | awk '{printf $1" "}'`
> sudo apt-get install qgis python-qgis
> It fails with:
> Unpacking qgis (1:2.13.0+git20160208+b712f3c+23wily) ...
> dpkg: error processing archive
> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160208+b712f3c+23wily_amd64.deb
> (--unpack):
>  trying to overwrite '/usr/bin/qgis.bin', which is the diverted
> version of '/usr/bin/qgis' (package: qgis-plugin-grass)
> dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
> Errors were encountered while processing:
> E: Sub-process /usr/bin/dpkg returned an error code (1)
If you've verified that no qgis packages are left installed after
removal, there is not much you can do to deal with the broken packaging.
`apt-get -f install qgis pyton-qgis` may work.
Kind Regards,
Bas
