[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
Jürgen E. Fischer jef at norbit.de
Fri Feb 12 07:12:34 PST 2016
Hi DelazJ,
On Fri, 12. Feb 2016 at 16:02:11 +0100, DelazJ wrote:
> Sorry. I tried a sudo apt-get install -f:
> Décompactage de qgis (1:2.13.0+git20160212+bcc8e2a+20trusty) sur (1:2.13.0+git20160202+8ca0ecf+20trusty) ...
> dpkg: error processing archive /var/cache/apt/archives/qgis_1%3a2.13.0+git20160212+bcc8e2a+20trusty_i386.deb (--unpack):
>  tentative de remplacement de « /usr/bin/qgis.bin », qui est la version détournée de « /usr/bin/qgis » (paquet : qgis-plugin-grass)
> dpkg-deb : erreur : le sous-processus coller a été tué par le signal (Relais brisé (pipe))
Which version of qgis-plugin-grass is installed?
dpkg -s qgis-plugin-grass
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160212/91796b3b/attachment.sig>
