[Qgis-developer] Error in Processing
    Pedro Venâncio
    pedrongvenancio at gmail.com
    Sun Feb 14 05:20:16 PST 2016
Alexander, Victor,
Will you update the version of Processing in the plugin manager (2.12.2),
soon?
2016-02-14 12:24 GMT+00:00 Pedro Venâncio <pedrongvenancio at gmail.com>:
> Thanks Alexander and Victor,
> I'll update that plugins!
> Best regards,
> Pedro
> 2016-02-14 10:51 GMT+00:00 Victor Olaya <volayaf at gmail.com>:
>> +1 to what Alex said
>> 2016-02-14 11:38 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> > Hi Pedro,
>> > GdalAlgorithm is an internal Processing class and should not
>> > be used in 3rd party plugins.
>> > The error happens because GdalAlgorithm class was refactored
>> > and new mandatory methods were introduced. Personally I think
>> > that all 3rd party plugins should use only public Processing API,
>> > e.g. GeoAlgorithm class.
>> > 2016-02-14 1:44 GMT+02:00 Pedro Venâncio <pedrongvenancio at gmail.com>:
>> >> Hi Alexander and Victor,
>> >> Actually the problem seems related with the new shortHelp function,
>> >> introduced in commit 62302377db1990485f7821f1ccef4ff6ef4d07d9.
>> >> Removing
>> >>     def shortHelp(self):
>> >>         return self._formatHelp('''This algorithm is based on the GDAL
>> %s
>> >> module.
>> >>                 For more info, see the <a href =
>> >> 'http://www.gdal.org/%s.html'> module help</a>
>> >>                 ''' %  (self.commandName(), self.commandName()))
>> >> from GdalAlgorithm.py prevents this error and these 3rd party plugins
>> works
>> >> ok.
>> >> Any hint to update them?
>> >> Thank you very much!
>> >> Best regards,
>> >> Pedro Venâncio
>> >> 2016-02-08 11:20 GMT+00:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> >>> Hi Paolo,
>> >>> this is not a Processing issue, but bug in 3rd party plugin.
>> >>> The bug is caused by fact that plugin uses internal Processing
>> >>> classes (which was changed) instead of subclassing public
>> >>> GeoAlgorithm class.
>> >>> 2016-02-08 13:10 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> >>> > Hi all,
>> >>> > I'm getting consistent errors in activating Processing on master,
>> see
>> >>> > below. Anyone has the same?
>> >>> > All the best.
>> >>> > An error has occurred while executing Python code:
>> >>> > AttributeError: RasterAT_MGIETRS89DirInv instance has no attribute
>> >>> > 'getConsoleCommands'
>> >>> > Traceback (most recent call last):
>> >>> >   File
>> "/usr/share/qgis/python/plugins/processing/gui/ProcessingToolbox.py",
>> >>> > line 105, in textChanged
>> >>> >     self._filterItem(self.algorithmTree.invisibleRootItem(), text)
>> >>> >   File
>> >>> > line 127, in _filterItem
>> >>> >     showChild = self._filterItem(child, text)
>> >>> >   File
>> >>> >   File
>> >>> >   File
>> >>> > line 135, in _filterItem
>> >>> >     if item.alg.shortHelp() is not None:
>> >>> >   File
>> "/usr/share/qgis/python/plugins/processing/algs/gdal/GdalAlgorithm.py",
>> >>> > line 56, in shortHelp
>> >>> >   File
>> >>> > line 64, in commandName
>> >>> >     name = alg.getConsoleCommands()[0]
>> >>> > Paolo Cavallini - www.faunalia.eu
>> >>> > QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> >>> > _______________________________________________
>> >>> > Qgis-developer mailing list
>> >>> > Qgis-developer at lists.osgeo.org
>> >>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> Alexander Bruy
>> > Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160214/f3837db4/attachment-0001.html>
