[Qgis-developer] 14 hours of broken travis build in master
Sandro Santilli
strk at keybit.net
Mon Feb 15 09:37:49 PST 2016
I've some pulls to merge but current master does not pass travis
since 14 hours: https://travis-ci.org/qgis/QGIS/builds
The first failure was after Nyall commit:
https://github.com/qgis/QGIS/commit/dfdcec89223d4167850c7ebbb0af1d65c21135f8
and is currently still failing in that area ("area" computation):
http://dash.orfeo-toolbox.org/testDetails.php?test=37439889&build=218090
Is anyone on the task of fixing current master build already ?
As a travis build takes about 1 hour, it may be advisable not to
push a change later than 1.5 hours before the end of the workday,
so to eventually revert a change that could be breaking.
--strk;
