[Qgis-developer] GRASS plugin broke only for me?
Radim Blazek radim.blazek at gmail.com
Tue Feb 16 23:52:45 PST 2016
The GRASS provider/plugin only works  if it is run with exactly the same
version of GRASS libs it was built with (GRASS init function in GRASS lib
is checking svn revision).
If you run QGIS with a different GRASS version you should get soft message
like
"GRASS init error: Problem in GRASS initialization, GRASS provider and
plugin will not work : Module built against version $Revision: 64732 $ but
trying to use version $Revision: 64007 $. You need to rebuild GRASS GIS or
untangle multiple installations."
The provider will load as invalid so you see just a directory structure not
GRASS location structure in the browser.
The plugin loads but all actions/tools are disabled except Options, where
you can manually select different GRASS installation (but not libraries the
provider/plugin is started with).
The "New mapset" action is left enabled because of bug, fixed in 8353698.
Radim
On Tue, Feb 16, 2016 at 12:36 PM, Ing. Pierluigi De Rosa <
pierluigi.derosa at gfosservices.it> wrote:
> Dear All,
> After the upgrading to the GRASS 7.03 I'm not able to have the GRASS
> plugin working properly.
> I'm using ubuntu with all software from repo; in particular I'm using:
> repo 1 for qgis http://qgis.org/ubuntugis/
> repo 2 for grass:
> http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
> I noticed that under Plugin -> Grass -> GRASS Option I still have grass
> 7.0.1 (the last installation) while I'm running GRASS 7.0.3
> If I run:
> GRASS --version I have:
> grass --version
> GRASS GIS 7.0.3
> Traceback (most recent call last):
>   File "/usr/bin/grass", line 1363, in <module>
>     parse_cmdline()
>   File "/usr/bin/grass", line 1275, in parse_cmdline
>     message('\n' + readfile(gfile("etc", "license")))
>   File "/usr/bin/grass", line 139, in readfile
>     f = open(path, 'r')
> IOError: [Errno 2] No such file or directory:
> '/usr/lib/grass70/etc/license'
> Could be that it miss the licence file in the package and this cause the
> plugin GRASS does not recognize GRASS data?
> In fact if I browse into the GRASS directory I'm not able to add any GRASS
> layer.
> If I ask to create e new mapset the QGIS crash
> Thank to all
> Pierluigi
> *Ing. Pierluigi De Rosa (PhD)*
> *Studio Associato GFOSSERVICES*
> *Presso CAMPUS Via F.lli Cairoli 25 - 06127 Perugia (PG) * *fax: 075
> 7823038*
> *cel: 3497558268*
> *web**: www.gfosservices.it
> <http://www.gfosservices.com/index.php?option=com_content&view=article&id=21&Itemid=21&lang=it>*
> *skype: pierluigi.derosa *
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160217/7c611f3f/attachment.html>
