[Qgis-developer] Output directory
Victor Olaya volayaf at gmail.com
Thu Feb 18 00:06:17 PST 2016
I added this handy method to our library of common utils
https://github.com/qgis/pyqgis_wrappers/blob/master/parfait/gui.py#L24
It basically stores the path entered by the user, along with the
caller method, so the next time the user is prompted for files from
that same method, it remembers the last folder. That way, plugin users
just need to use this method instead of doing it the normal qt way,
and they do not have to worry about storing last paths.
The function to find out the caller method name uses introspection and is here:
https://github.com/qgis/pyqgis_wrappers/blob/master/parfait/utils.py#L7
Might need some improvements and testing, but the idea is there, in
case it might be useful
Cheers
2016-02-18 8:49 GMT+01:00 Nathan Woodrow <madmanwoo at gmail.com>:
> Thanks Nyall.
> I didn't touch ftools and gdal tools because I had a feeling they would go
> away in future
> On Thu, 18 Feb 2016 5:41 pm Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On 18 Feb 2016 18:38, "Paolo Cavallini" <cavallini at faunalia.it> wrote:
>> > Hi all,
>> > a long standing issue in QGIS is the fact that several commands and core
>> > plugins (not to speak about external plugins) do not honour the "last
>> > used directory rule" for saving files. As a result, the behaviour is
>> > unpredictable and confusing.
>> > I would suggest:
>> > * do a thorough revision of the default destination dir for all commands
>> > (I hope this can be done programmatically)
>> > * maybe adding an option "Always save in the default output directory",
>> > just like the Download dir in Firefox
>> > * making this the default also for external plugins.
>> > Thoughts?
>> > All the best.
>> Nathan did a huge amount of work on that front during this cycle. Do you
>> have specifics of any which don't behave correctly now?
>> Also worth noting that Denis did some work implementing a reusable file
>> picked widget with correct handling for all this. We just need to switch
>> across all the various custom file pickers to this standard widget
>> (hopefully in 2.16?)
>> Nyall
>> > Paolo Cavallini - www.faunalia.eu
>> > QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
