[Qgis-developer] Custom output folder for Processing overlooked
Victor Olaya volayaf at gmail.com
Thu Feb 18 06:53:59 PST 2016
The custom folder is not for temp files
it is for files without a full path, so if you enter "myfile.shp", it
will put it in [custom_folder]/myfile.shp
that way you dont have to write the full path in case you want all
your final (not temp) outputs in the same folder
It is described in the manual :-P
Hope this helps
2016-02-18 15:50 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all,
> if I set up a custom folder to store as a default the output of
> Processing, the layers are still saved in temp.
> Checked on Debian and Windows, current master.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
