[Qgis-developer] A common set of functions for QGIS plugins
Neumann, Andreas
a.neumann at carto.net
Fri Feb 19 04:24:46 PST 2016
The upcoming user conference in Girona may be a good opportunity to
present and advertise about both the common set of Python functions, but
also about the standard and custom widgets.
The CfP is still running and they are looking for more submissions.
Maybe someone could do a presentation for Python plugin authors to make
them aware?
Andreas
On 2016-02-19 11:36, Denis Rouzaud wrote:
> On 02/19/2016 11:29 AM, Nyall Dawson wrote:
>> On 19 Feb 2016 19:35, "Etienne Trimaille" <etienne.trimaille at gmail.com> wrote:
>>> I'm discovering that 'old' topic.
>>> Yes, I really like the idea, but I wasn't aware about that.
>>> I think the UI should be more uniform between plugins and QGIS, for instance to have :
>>> - the same combobox about layers (using the symbol for the geometry type and the EPSG if the checkbox is checked in the Processing settings)
>>> - the same combobox for table fields (symbol with the kind of field : integer, char ...)
>>> - the same output field with the menu (save to temp file, save to vector file, save to ...) like in processing.
>> Just a little advice - we need to push people toward the standard widgets for these, eg QgsFieldComboBox, QgsMapLayerComboBox. Reimplementing then with new Python versions isn't a good idea, since it breaks consistency with core (and is also a lot of extra work!)
> I would say, we even need to advertise the custom widgets.
> All these widgets are availble in Qt Designer, it's quite easy to use them from there.
>> Nyall
>>> So I will try to use that and contribute to these wrappers if I can.
>>> By the way, is it possible to recommend on the pyqgis cookbook (or the qgis documentation) to use the processing framework more often ? A lot of plugins are useful but we can't use them in batch mode or in complex workflow. Moreover, they often produce only shapefile.
>>> There are some very nice settings in Processing like "use selected features", default output format for vector and raster ... I think plugins should try to more compliant with these settings.
>>> 2016-02-19 8:55 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>>>> Il 19/02/2016 08:53, Victor Olaya ha scritto:
>>>>> I dont think it wil hurt to add it to the main repo. While we develop,
>>>>> and the methods are not used yet, it will be just a bunch of files
>>>>> with dead code, so it is not risky, and maybe it is easier to engage
>>>>> people that way
>>>> I'd vote for it.
>>>> Thanks, Victor.
>>>> Paolo Cavallini - www.faunalia.eu [1]
>>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Links:
[1] http://www.faunalia.eu
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160219/89fb3bd1/attachment-0001.html>
