[Qgis-developer] QtWebKit 2.3
enricofer enricofer at gmail.com
Thu Feb 25 05:10:13 PST 2016
I Agree with Tom. I have several plugins not released due to QWebKit
issues. It would be wonderful to have an up to date Qgis LTR supporting
QwebKit 2.3, before Qgis 3.0.
https://forum.qt.io/topic/57899/building-qt-4-8-7-and-qtwebkit-2-3-4-separately-with-vs2012-on-windows
2016-02-25 12:10 GMT+01:00 Tom Chadwin [via OSGeo.org] <
ml-node+s1560n5252791h90 at n6.nabble.com>:
> OpenLayers is moving away from the Closure library. This is A Good Thing,
> as abandoning Closure will decrease OpenLayers' filesize considerably.
> However, it means that OpenLayers now doesn't work on older browsers.
> While not a big deal for end-users' desktop browsers, as very few are
> affected, it's a problem for QGIS plugin developers.
> Qt4.8 uses QtWebKit 2.2 (I believe), and this *is* affected. It can be
> fixed by adding two polyfills (likely to increase in number in the future).
> qgis2web uses QtWebKit for its preview, so I've had to add the polyfills.
> I don't like doing this, as it adds bloat, and at the moment (unless I
> redesign the code), the polyfills are added to exported maps as well, which
> really don't need them.
> QtWebKit 2.3 was developed and released as a community project, outwith
> the Qt project. 2.3 includes an up-to-date WebKit version, so it would fix
> these problems. Can anyone give an opinion on whether it would be possible
> to package QtWebKit 2.3 with qgis2web?
> I obviously realize that QGIS3 will remove this issue, with Qt5. However,
> QGIS3 is a while off yet - there will be several OL3 releases until then -
> and QGIS2 is likely to remain in use for a long time.
> Does anyone have an opinion, or any expertise in this area?
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/QtWebKit-2-3-tp5252791.html
> To unsubscribe from Quantum GIS - Developer, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4099106&code=ZW5yaWNvZmVyQGdtYWlsLmNvbXw0MDk5MTA2fDcwMTIyMjE0OA==>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/QtWebKit-2-3-tp5252791p5252814.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160225/592030f2/attachment-0001.html>
