[Qgis-developer] Error on startup on master
    Stefan Ziegler
    stefan.ziegler.de at gmail.com
    Sat Jan  9 01:44:31 PST 2016
It is this typical python plugin errror window.
I miss the "tests" directory in my install dir (which exists on another
machine). Anything special to set in cmake?
cmake .. -DCMAKE_BUILD_TYPE=Release
-DCMAKE_INSTALL_PREFIX=/usr/local/qgis_master
-DCMAKE_INSTALL_RPATH=/usr/local/qgis_master/lib -DENABLE_TESTS=OFF
-DWITH_SERVER=OFF -DWITH_CUSTOM_WIDGETS=ON -DWITH_PYSPATIALITE=ON
-DWITH_QSPATIALITE=ON -DGDAL_CONFIG=/usr/local/gdal_master/bin/gdal-config
-DGDAL_INCLUDE_DIR=/usr/local/gdal_master/include
-DGDAL_LIBRARY=/usr/local/gdal_master/lib/libgdal.so
-DWITH_INTERNAL_QWTPOLAR=ON
regards
Stefan
On Sat, Jan 9, 2016 at 4:04 AM, Michael Kirk <michael.john.kirk at gmail.com>
wrote:
>> Hi
>> On a fresh installed Ubuntu 14.04 machine a get the following error with
>> a compiled master:
>> Couldn't load plugin 'processing'
>> ImportError: No module named tests.TestData
>> Regards
>> Stefan
>> Freundliche Grüsse
>> Stefan Ziegler
>> Kantonsgeometer
>> Amt für Geoinformation
>> Rötistrasse 4
>> 4500 Solothurn
>> Telefon +41 32 627 75 96
>> Telefax +41 32 627 75 98
>> stefan.ziegler at bd.so.ch
>> http://www.so.ch
> Hi,
> Im not on ubuntu - but not seeing this error on Mac/master. Where are you
> seeing the error, in terminal when you launch the app, or in the python
> console in QGIS? Is it preventing you from launching the app?
> Presumably this is about: python/plugins/processing/tests/TestData.py
> M
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160109/c1323898/attachment.html>
