[Qgis-developer] Geometry modifiers for labeling
Matthias Kuhn
matthias at opengis.ch
Wed Jan 13 06:29:02 PST 2016
Hi Andreas
On 01/13/2016 03:23 PM, Andreas Neumann wrote:
> Hi Matthias,
> You mean I should then set the data-defined label position to the
> start and the endpoint of the line?
> Yes - this kind of works, but I would have to calculate the
> orientation/direction of the first and last segment of the line myself.
> But we are getting closer to solving this issue ;-) ...
I see, you would actually not only want to set the position but also the
orientation.
Yes, that would be less clumsy with a modifier that extracts the first
and last segment. Certainly something that can be done.
Matthias
> Andreas
> On 13.01.2016 15:01, Matthias Kuhn wrote:
>> Good to know.
>> So that should work find with my previous recommendation of using
>> "Placement" -> "Data Defined"?
>> On 01/13/2016 02:59 PM, Andreas Neumann wrote:
>>> Hi Matthias,
>>> You can just add several rules that all apply at the same time (e.g.
>>> two times an empty rule only bound by map scale ranges).
>>> In the placement options use one time "above line", and the other time
>>> " below line".
>>> This works fine. See screenshot at
>>> http://www.carto.net/neumann/temp/label_multiple_times.png
>>> The workaround with font-markers from Matthieu works fine, but it is
>>> ugly that the labels can be up-side-down.
>>> Andreas
>>> On 13.01.2016 14:45, Matthias Kuhn wrote:
>>>> Hi Andreas
>>>> On 01/13/2016 01:59 PM, Andreas Neumann wrote:
>>>>> Hi Matthias,
>>>>> Yes - with the new rule-based renderer we can label a line several
>>>>> times
>>>>> - e.g. have one label above the line and another with another label
>>>>> text
>>>>> below the line.
>>>> I can't find the possibility to label the same feature twice, only
>>>> different labeling rules for different features.
>>>> But I guess you can use "data defined placement" instead of "above" or
>>>> "below"?
>>>> Matthias
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160113/96b2d5dc/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160113/96b2d5dc/attachment.sig>
