[Qgis-developer] GDAL 2.1 can update Geojson files - What is missing in QGIS to edit GeoJSON files ?
Matthias Kuhn
matthias at opengis.ch
Thu Jan 14 07:38:43 PST 2016
Hi Michaël
On 01/14/2016 04:18 PM, kimaidou wrote:
> Hi QGIS,
> I have read that GDAL can now update GeoJSON since version 2.1.0. See [1]
> If I build QGIS with GDAL 2.1, would I be able to edit the GeoJSON as
> I can for Shapefiles ? For the record, capabilities are defined here [2]
> Perhaps the GDAL doc about "updating existing GeoJSON files" has a
> different meaning that the need raised by Even Rouault here [3]
> Or is the best approach to create a specific QGIS driver for GeoJSON ?
> I would try to propose a PR for this if this is the best way to go.
Giving GDAL 2.1 a try will be way less effort than implementing a
GeoJSON driver inside QGIS. And if there are things still left to be
fixed, it's probably better to fix things on the GDAL end since this way
the support for it is in a library shared by many FOSSGIS tools.
(Please note that this recommendation is only meant for non-database
providers. Feel free to propose a native GeoPackage driver ;) )
All the best
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160114/ed729ce9/attachment.sig>
