[Qgis-developer] Managing Python dependencies automatically for the user
Luigi Pirelli luipir at gmail.com
Fri Jan 15 04:26:26 PST 2016
e.g.
http://stackoverflow.com/questions/14050281/how-to-check-if-a-python-module-exists-without-importing-it
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 15 January 2016 at 13:24, Luigi Pirelli <luipir at gmail.com> wrote:
> btw an exception can be caouse by other dependencies of openpyxl => better
> to check the correct exception than a generic one
> Luigi Pirelli
> * Mastering QGIS:
> On 15 January 2016 at 13:23, Luigi Pirelli <luipir at gmail.com> wrote:
>> thank you for sharing
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 15 January 2016 at 12:12, Pablo Fernández Moniz <
>> pablofernandezmoniz at gmail.com> wrote:
>>> First of all, thank you very much for all the fast replies, they have
>>> been very helpful for us.
>>>  The solution we finally implemented was adding the .egg file for the
>>> dependency and loading it when the wider system import fails in the
>>> following fashion:
>>> import os
>>> import sys
>>> try:
>>>     import openpyxl
>>> except:
>>>     package_name = "openpyxl-2.3.2-py2.7.egg"
>>>     package_path = os.path.join(os.path.dirname(__file__), package_name)
>>>     sys.path.append(package_path)
>>>     import openpyxl
>>>  This may not be a solution for every use case but it gets the job done
>>> for us in our setup.
>>>  Once again, thank you for he fast replies and ideas given.
>>>  Kind regards,
>>> 2016-01-15 4:40 GMT+00:00 Andreas Neumann <a.neumann at carto.net>:
>>>> Note that the Windows binaries already contain xlwt and xlrd. Jürgen
>>>> was so kind to include it, because I needed it as well for my plugins. Not
>>>> sure about openpyxl. On Linux systems it is rather easy to install them
>>>> through apt-get, pip or similar mechanisms. Just tell your users that/how
>>>> they need/can install them.
>>>> Andreas
>>>> On 14.01.2016 22:13, Matthias Kuhn wrote:
>>>> Hi Pablo, Tim
>>>> On 01/14/2016 10:00 PM, Tim Sutton wrote:
>>>> Hi
>>>> On 14 Jan 2016, at 18:06, Pablo Fernández Moniz <
>>>> Hi!
>>>>  We are currently developing a QGIS plugin were we wish to generate
>>>> some Excel files as output.
>>>>  In order to build the spreadsheet file we need to use some python
>>>> modules installed from pip (openpyxl, xlwt, etc). This dependency will
>>>> force every user to manually install the needed package form the pip
>>>> repository.
>>>>  This situation leaves us with the following question: is possible or
>>>> it will be in the future to manage this kind of dependencies from QGIS side
>>>> when the user installs the plugin?
>>>> Although it has been discussed and some prototyping was done to support
>>>> automatic installation of dependencies at the last hackfest, there isn’t
>>>> anything in the released versions of QGIS to support this yet. If your
>>>> packages have no operating system specific binaries in them, then I suggest
>>>> to bundle them into your plugin and use an appropriate import path relative
>>>> to your code. Note there is a limit on how big your plugin can be (I think
>>>> it is 10mb) so you need to ensure your 3rd party deps do not bulk out your
>>>> plugin too much.
>>>> We bundled xlwt and xlrd as .egg with a plugin recently:
>>>> https://github.com/opengisch/shpsync/blob/master/xlwt-1.0.0-py2.7.egg
>>>> https://github.com/opengisch/shpsync/blob/master/xlrd-0.9.4-py2.7.egg
>>>> Until there's a cross-platform dependency management (which I know that
>>>> several people are looking into) that's the safest road to follow.
>>>> Best
>>>> Matthias
>>>> Regards
>>>> Tim
>>>>  Thank you for your time!
>>>>  Kind regards.
>>>> GIT Analyst
>>>> Web <http://www.pablofm.com/>    Linkedin
>>>> <http://www.linkedin.com/in/pablofernandezmoniz/>   Twitter
>>>> <http://www.twitter.com/monizpablo>
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Tim Sutton
>>>> Visit  <http://kartoza.com>http://kartoza.com to find out about open
>>>> source:
>>>> * Desktop GIS programming services
>>>> * Geospatial web development
>>>> * GIS Training
>>>> * Consulting Services
>>>> Skype: timlinux Irc: timlinux on #qgis at freenode.net
>>>> Tim is a member of the QGIS Project Steering Committee
>>>> Kartoza is a merger between Linfiniti and Afrispatial
>>>> Qgis-developer mailing listQgis-developer at lists.osgeo.org
>>>> Matthias Kuhn
>>>> OPENGIS.ch - https://www.opengis.ch
>>>> Spatial • (Q)GIS • PostGIS • Open Source
>>> GIT Analyst
>>> Web <http://www.pablofm.com>    Linkedin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160115/7668cc2c/attachment.html>
