[Qgis-developer] Processing provider versions and hard coded path in settings
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Mon Jan 25 06:56:04 PST 2016
Hi Victor and Alex,
Thanks for your detailed replies!
That is nice, I was not aware that the paths are "auto-detected".
I now removed the respective settings from my QGIS.ini and GRASS 6 got detected properly.
However, when I tried GRASS 7 algorithms, I got a Python error:
TypeError: object of type 'NoneType' has no len()
File "C:\Users\stefan.blumentrath\.qgis-custom/python/plugins\processing\gui\ProcessingToolbox.py", line 192, in executeAlgorithm
message = alg.checkBeforeOpeningParametersDialog()
File "C:\Users\stefan.blumentrath\.qgis-custom/python/plugins\processing\algs\grass7\Grass7Algorithm.py", line 531, in checkBeforeOpeningParametersDialog
msg = Grass7Utils.checkGrass7IsInstalled()
File "C:\Users\stefan.blumentrath\.qgis-custom/python/plugins\processing\algs\grass7\Grass7Utils.py", line 359, in checkGrass7IsInstalled
cmdpath = os.path.join(path, 'bin', 'r.out.gdal.exe')
File "C:\OSGeo4W\apps\Python27\lib\ntpath.py", line 96, in join
assert len(path) > 0
Python version: 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
QGIS version: 2.12.3-Lyon Lyon, 02885d5
So, I had a look at Grass7Utils.py and filed PR #2720.
Sorry for the conflicts in the PR (I just changed two lines). I am a git-beginner...
That should make path detection work for GRASS 7 again.
Yet, folder layout is OSGeo4W\apps\grass\grass-7.0.3RC2. But in OSGeo4W\apps\grass\, there can be also a grass-7.0.2 folder present in addition...
Cheers
Stefan
-----Original Message-----
Sent: 25. januar 2016 13:22
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Cc: Alexander Bruy <alexander.bruy at gmail.com>; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Processing provider versions and hard coded path in settings
Stefan,
here is a quick explanation
The paths are not hardcoded on the first install. Instead, Processing tries to find those dependencies (which usually works fine in osgeo4w distributions),or lets the user configure them manually. Once they are configured manually (as you have done), that value is stored as a setting (and written to the ini file for further uses). If you change your QGIS version or Processing version, the configuration is not changed, so it will use that value again and again (and since it is already configured, a new version of Processing wont try to find those dependencies).
The only solution to that is to have different ini files and specify which one to use in each case, using the --configpath option
Cheers
2016-01-25 12:54 GMT+01:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Hi Alex,
> Thanks for your reply, and sorry if my question was a bit unclear...
> When I want to use e.g. GRASS 7 in Processing, I have to provide the
> path to the "GRASS7 folder" in Processing --> Processing Options --> Providers From there, in my case e.g. "C:\Program Files (x86)\QGIS Lyon\apps\grass\grass-7.0.3RC2" has been saved as an absolute path to my QGIS.ini file in my home directory.
> If I use different QGIS versions in parallel (e.g. latest stable and LTR) the path can change. Furthermore, I have to update it manually, after each update of GRASS or SAGA (because then the paths change as well...
> This is what I meant, not the source code...
> But maybe it would be better to have the paths themselves more stable...
> Recently, Helmut Kudrnovsky did some work on making RStudio available in the GRASS console in OSGeo4W. Maybe something like this is needed to grab the path to GRASS, SAGA or R for processing...?
> Cheers
> Stefan
> From: Alexander Bruy [mailto:alexander.bruy at gmail.com]
> Sent: 25. januar 2016 12:13
> Cc: qgis-developer at lists.osgeo.org
> Hi Stefan,
> Processing providers are just plugins, so they installed in the global QGIS plugins directory. There is no hadrcoding in Processing sources related to the providers.
> 2016-01-25 12:04 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
>> Dear devs,
>> In my QGIS.ini, the paths to the Processing providers are hard coded,
>> which means I have to manually adjust them after every software
>> update (Saga, GRASS, R).
>> Any chance to pass the updates to the user(s)`s QGIS settings (or
>> make QGIS recognizing the Processing providers installed together
>> with QGIS), or is this only a limitation of the --configpath solution?.
>> Should I extend:
>> http://hub.qgis.org/issues/12623
>> (as it seems related) or should I open a new ticket (in case this
>> wanted and feasible of course)...
>> Kind regards,
>> Stefan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
