Attempts to add a test for QgsMapToolNodeTool result in failures due to the class not being exported. Is there a policy about what to do in these cases ? Should I just export the class or is there some other test-oriented trick ? --strk; () Free GIS & Flash consultant/developer /\ https://strk.kbt.io/services.html
