[Qgis-developer] Build failure following qt creator setup instructions
Andrea Aime
andrea.aime at geo-solutions.it
Sun Jul 3 05:18:02 PDT 2016
I'm trying to setup qgis source code in QT creator on a freshly installed
Linux Mint 18 (released a few days ago).
The instructions seem to mostly work, except once building I get into this
error:
Generating pyqgis api file
[ 82%] Built target qsci-api
[ 82%] Built target pyfuture
[ 82%] Built target zzz-GdalTools-3-depend
[ 82%] Built target zzz-GdalTools-1-depend
[ 82%] Built target pyqtcompat
[ 82%] Built target pygui
[ 82%] Built target pycore
[ 82%] Generating ui_widgetSieve.py
File "/home/aaime/devel/qgis/scripts/pyuic-wrapper.py", line 26, in
<module>
import qgis.PyQt.uic.pyuic
ImportError: No module named PyQt.uic.pyuic
python/plugins/GdalTools/tools/CMakeFiles/zzz-GdalTools-2-depend.dir/build.make:117:
recipe for target 'python/plugins/GdalTools/tools/ui_widgetSieve.py' failed
CMakeFiles/Makefile2:5637: recipe for target
'python/plugins/GdalTools/tools/CMakeFiles/zzz-GdalTools-2-depend.dir/all'
failed
Makefile:160: recipe for target 'all' failed
make[2]: *** [python/plugins/GdalTools/tools/ui_widgetSieve.py] Error 1
make[1]: ***
[python/plugins/GdalTools/tools/CMakeFiles/zzz-GdalTools-2-depend.dir/all]
Error 2
make: *** [all] Error 2
13:54:45: The process "/usr/bin/make" exited with code 2.
Error while building/deploying project qgis2.15.0 (kit: Desktop)
When executing step "Make"
13:54:45: Elapsed time: 00:15.
I've installed the required dependencies following instructions in this
line of the INSTALL guide:
https://github.com/qgis/QGIS/blob/master/INSTALL#L190
and I've verified that pyuci4 and associated libraries are installed, e..g:
> sudo apt-get install pyqt4-dev-tools pyqt4.qsci-dev
Lettura elenco dei pacchetti... Fatto
Generazione albero delle dipendenze
Lettura informazioni sullo stato... Fatto
pyqt4-dev-tools is already the newest version (4.11.4+dfsg-1build4).
pyqt4.qsci-dev is already the newest version (2.9.1+dfsg-4build1).
0 aggiornati, 0 installati, 0 da rimuovere e 14 non aggiornati.
Any clue as to why the build is failing?
I've also tried following the Ubuntu instructions inj
https://github.com/qgis/QGIS/blob/master/INSTALL,
in that case ccmake fails to find qwtpolar, which does not seem to be a
package included in Mint 18
(I've found libqwt5-qt4 and installed it, but it did not help)... does one
has to hand build this package
in order to build qgis?
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160703/5e0e57b6/attachment-0001.html>
