[Qgis-developer] Expressions - performances of spatial operators
Matthias Kuhn
matthias at opengis.ch
Tue Jul 5 06:31:14 PDT 2016
Hi Michaël,
There are a couple of possibilities to improve the performance of
operations in two ways (which both help here AFAICS)
* Give QgsExpression::prepare() more power
* Compile functions (where possible)
The send one depends to some degree on the first one.
Let me know if you have sponsors, I've got some experimental code
somewhere and I am very interested in working on this project.
FYI, a first test - only the prepare part - some months ago improved the
2.5D rendering by ~30%.
Regards
Matthias
On 07/05/2016 03:11 PM, kimaidou wrote:
> Hi all,
> I am a bit curious about performances concerning the use of Spatial
> expressions in QGIS, for example to select features like this
> intersects(
> $geometry,
> geom_from_wkt( 'MultiPolygon (((649308.28000000002793968
> 6978002.05999999959021807, 649295.32999999995809048
> 6977994.54999999981373549, 649235.92000000004190952
> 6978013.50999999977648258, 649182.53000000002793968
> 6978077.32000000029802322, 649212.34999999997671694
> 6978159.53000000026077032, 649308.28000000002793968
> 6978002.05999999959021807)))')
> NB: I have simplified the WKT representation here
> I am running this expression inside QGIS 2.14, for a layer containing
> approx. 100 000 features ( buildings).
> The WKT polygon represents a very small area compared to the whole
> layer: 500 features only are selected.
> It seems to me no spatial index is used, because it takes some time to
> run ~ 3 minutes.
> I have checked the option to run expressions server side, and all the
> layers are PostGIS layers.
> What could be done to improve this kind of expressions, which can be
> used elsewhere in QGIS ( to toggle labels for example ) ?
> Regards
> Michaël
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
