[Qgis-developer] Too many tests failing
Radim Blazek radim.blazek at gmail.com
Fri Jul 15 09:16:40 PDT 2016
I have compiled current master and run ctest after some time and 46
tests are failing here: 10 simply failed, 28 double free or
corruption, 4 corrupted double-linked list. Obviously, the problem is
local, so what is the trick to get less tests failing? Qt 4.8.6, clang
3.5.0, Debian Jessie 64 bit.
Radim
