[Qgis-developer] QGIS compile error
Vincent Schut schut at satelligence.com
Mon Jul 18 06:35:02 PDT 2016
Just fyi: same error here (qgis master, gdal trunk, linux (opensuse leap):
[  0%] Built target version
Building CXX object src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o
Best regards, let me know if you need more info),
Vincent.
On Monday, July 18, 2016 12:18:25 PM Stefan Ziegler wrote:
Hi
I get some compile errors on master (Ubuntu 16.04 and 14.04):
[  0%] Building CXX object
src/core/CMakeFiles/qgis_core.dir/composer/qgscomposition.cpp.o[  0%] Building CXX
object
src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o/home/stefan/sources/qgis_master/src
/core/pal/pal.cpp:125:3: error: reference to ‘RTree’ is ambiguous   RTree<FeaturePart*,
double, 2, double> *obstacles;   ^In file included from
/home/stefan/sources/qgis_master/src/core/pal/feature.h:33:0,                 from
/home/stefan/sources/qgis_master/src/core/pal/pal.cpp:37:/home/stefan/sources/qgis
_master/src/core/pal/pointset.h:38:7: note: candidates are: class RTree class RTree;
src/core/CMakeFiles/qgis_core.dir/build.make:7466: recipe for target
'src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o' failedmake[2]: ***
[src/core/CMakeFiles/qgis_core.dir/pal/pal.cpp.o] Error 1CMakeFiles/Makefile2:208:
recipe for target 'src/core/CMakeFiles/qgis_core.dir/all' failedmake[1]: ***
[src/core/CMakeFiles/qgis_core.dir/all] Error 2Makefile:149: recipe for target 'all'
failedmake: *** [all] Error 2
best regards
Stefan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160718/beafef1c/attachment.html>
