[Qgis-developer] Perfs: a lot of WKB conversions
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Tue Jul 19 02:08:24 PDT 2016
Hi Nyall,
On Tue, Jul 19, 2016 at 10:25 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> See https://github.com/qgis/qgis3.0_api/issues/15
Cool, that would force us to use the coordinates directly instead of the
WKB.
> We can't use a QPolygonF, as it uses qreal for storage. For certain
> architectures this is float, not double, and so is unsuitable for
> storing coordinates.
I was a bit sceptical, so I did a quick computation. A 32 bit float allows
an accuracy of 3mm with WGS84 for coordinates around 180°:
180 takes 8 bits out of the 23 bits of fraction. The remaining 15 bits can
split the earth circumference into chunks of 3mm (40000/(2^15)). I'm maybe
off by +1 bit of precision (the fraction has an implicit 1 at MSB), so that
would be 1.5mm.
Other coordinate systems have offsets. For example CH1903+ which has an
offset of 2e6 that is reducing the precision of a float coordinate to 13cm.
Makes sense to use 64bits floats.
But then, we transform into screen coordinates after we converted to
QPolygonF. We loose the precision anyway. Isn't that a problem? But I'm
digressing and this is a problem only for ARM.
I think the first logical step would be converting the clipper to work
> directly with QgsAbstractGeometryV2, so that QgsSymbol can avoid one
> of the to/from conversions at least.
IMHO, implementing my proposed heuristic for not simplifying some
geometries would lead to better gains and is less changes to the code.
Usually, features that are around a few pixel of size are not rendered.
Their class should be filtered out by the scale range, if the layer style
is correctly tuned.
Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160719/88417a21/attachment.html>
