[Qgis-developer] WFS Provider Strategies
Andrea Aime andrea.aime at geo-solutions.it
Wed Jul 20 09:35:41 PDT 2016
On Wed, Jul 20, 2016 at 6:17 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> The issues were with multiple layer joins with GeoServer in some
> circumstances not very
> clearly understood ( I don't want to particularly point fingers at
> GeoServer, as server side joins is a pretty advanced feature rarely
> implemented by servers)
The WFS 2.0 joining implementation in GeoServer can certainly use some
love. Some fixes have been
made in the last year, but there is still a significant limitation, the
join has to be a "star" one,
with a central feature type joining with the others, while a list one
cannot be made, e.g.:
* ((T1 join T2) join T3) can always be made (by reshuffling thing so that
T2 is the center)
* ((T1 join T2) join T3) join T4) cannot be implemented without changing
the API down in GeoTools instead, that would be quite a bit of work
(sponsorship welcomed ;-) )
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160720/6870b378/attachment-0001.html>
