[Qgis-developer] Singleband pseudocolor GUI is too wide for styling panel
Anita Graser anitagraser at gmx.at
Thu Jul 28 01:34:28 PDT 2016
On Thu, Jul 28, 2016 at 10:01 AM, Mathieu Pellerin <nirvn.asia at gmail.com>
wrote:
> The problem with moving the [ edit ] button and the [x] invert checkbox
> below the combo box is that it'd end up eating vertical space, which is as
> precious and needed as horizontal spacing :)
​I'd rather scroll vertically than horizontally.
Concerning vertical space: The Layer rendering and Resampling sections
should be collapsible like the Load min/max values section. Actually, I
think Layer rendering and Resampling are probably used less than Load
min/max.
Best wishes,
Anita
> On Thu, Jul 28, 2016 at 2:26 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> Hi Mathieu,
>> On Thu, Jul 28, 2016 at 5:32 AM, Mathieu Pellerin <nirvn.asia at gmail.com>
>> wrote:
>>> Hey Anita,
>>> Having worked on reducing the width of the rendering UIs in the last dev
>>> cycle, I'm familiar with the issue raised here :)
>>> Basically, the singleband pseudocolor renderer's minimum width is
>>> determined (ATM) by the "Color [ramp]" row. More specifically, if you have
>>> a color ramp with a long label, your combo box is going to eat a lot of
>>> horizontal space. There's a lot that can be easily done to alleviate that
>> ​Thank you for the insights! That makes sense. Maybe as a first simple
>> step we could just rearrange the Edit and Invert buttons and move them
>> below the color ramp combo box. The combo box itself could also have a
>> maximum size which truncates longer ramp names.
>> Should I open a ticket?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160728/a2d301b9/attachment.html>
