[Qgis-developer] (Yet again) SAGA support badly broken in QGIS
Neumann, Andreas
a.neumann at carto.net
Wed Jun 1 05:16:37 PDT 2016
If you guys think about integrating SAGA closer into QGIS, could we also
fix the issue that SAGA is currently limited to reading Shapefiles for
vector input? Probably a lot of work - but would this be feasible?
Greetings,
Andreas
On 2016-06-01 12:23, Alexander Bruy wrote:
> If we decide to go this way, I'd suggest to put SAGA algs
> into QGIS analysis library, so we can add Python bindings
> to them too. Also in this case everyone can access them
> similarly to qgis.core and qgis.gui.
> 2016-06-01 12:57 GMT+03:00 Victor Olaya <volayaf at gmail.com>: I am familiar with SAGA source code, and algorithms are independent
> and self contained, very modular structure, so it should be easy to
> use them. There is a lot of work in there, since the number of
> algorithms is very large, but it can be a progressive thing. Having
> the in the QGIS source code would be fantastic.
> If we decide to go in this direction, we can maybe get rid of the SAGA
> provider in core, and have it as a separate plugin (and maybe a ship
> SAGA itself with the plugin??), for those wanting to run SAGA itself.
> In core we would add native Processing algorithms that would use the
> QGIS native functionality that we clone from SAGA. There is no need to
> port everything, at first just the most common ones or those that have
> no equivalent in other providers. Better a reduced set of robust and
> commonly used algs than a large colelction of them that is not so
> stable as it should.
> Not sure how we can tackle this, but definitely it is an option to
> consider. It would solve all issues with format conversions, etc... so
> it's clearly worth a try.
> My 2 cents
> Cheerss
> 2016-06-01 11:11 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>: Il 01/06/2016 10:51, Tom Chadwin ha scritto:
> Would it be fair to say that non-Windows users are more likely to be able to
> handle other ways around this issue?
> not in an easy and clean way.
> Better a general solution than a hack.
> All the best.
> Paolo Cavallini - www.faunalia.eu [1]
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Links:
[1] http://www.faunalia.eu
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160601/7d5a69be/attachment.html>
