[Qgis-developer] About feature simplification rendering
A Huarte
ahuarte47 at yahoo.es
Fri Jun 3 03:28:18 PDT 2016
Hi, a few days ago a related pull was merged:
https://github.com/qgis/QGIS/pull/2900
As Nathan said, the simplification only runs in rendering tasks, but before this pull, the original geometry readed from a data source could be simplified when the "simplify" flag is defined in the QgsFeatureRequest used by a FeatureIterator.
Now the geometries never are simplified, the simplification runs using its WKB representation just before it is drawn.
Alvaro
De: Nathan Woodrow <madmanwoo at gmail.com>
Para: roy roy <royroge at outlook.com>
CC: qgis-developer <qgis-developer at lists.osgeo.org>
Enviado: Viernes 3 de junio de 2016 12:11
Asunto: Re: [Qgis-developer] About feature simplification rendering
Hey Roy,
Simplification is only for display reasons. Editing will return the full geometry or else that would be bad.
- Nathan
On Fri, Jun 3, 2016 at 8:04 PM, roy roy <royroge at outlook.com> wrote:
Hi, i've searched in the docs and the web and cannot find
this info, just because i'd like to be sure:
Can the use of feature simplification (Option Rendering) affect
in any way my geoprocessing workflow (e.g. using clip, difference etc...)?
i ran some test and it seems it does not, i.e. geoprocessing results are
not affected by feature simplification option (as it should be I think)
Am I correct?
Thanks, Roy.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160603/b1584361/attachment.html>
