[Qgis-developer] What is the name for "pyspatialite" package in fedora 19?
Sebastiaan Couwenberg sebastic at xs4all.nl
Mon Jun 6 22:01:16 PDT 2016
On 06/07/2016 05:15 AM, 童言 wrote:
> Thank you very much! But would you please tell me how to use the embedded copy included in the QGIS 2.14.3 source. I can't figure it out by myself.
Have you tried the instructions from the INSTALL file, it documents the
build procedure for Fedora too?
 https://github.com/qgis/QGIS/blob/master/INSTALL#L366
If you look through the CMake options, you'll find WITH_PYSPATIALITE
which you need to enable to have the embedded copy built along with the
rest of QGIS.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
