[Qgis-developer] Report 2 - QGIS Symbology Sharing Tools
Alessandro Pasotti
apasotti at gmail.com
Wed Jun 8 00:41:43 PDT 2016
2016-06-08 9:21 GMT+02:00 Akbar Gumbira <akbargumbira at gmail.com>:
> Yes, I have tried it. We can do it with sparse checkout, but, it requires
> git on the client.
Wasn't that a requisite? If we are going to use git as a storage we need a
git client (pure python seems to exist, could be used as a fallback in case
git is not installed in the system) https://github.com/jelmer/dulwich .
BTW: if you do not want to deal with git in this first task, you could used
the zip endpoint, and assume that the metadata will be available at a known
location in the remote http repo and just wget it.
> On Wed, Jun 8, 2016 at 9:18 AM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> 2016-06-08 9:10 GMT+02:00 Akbar Gumbira <akbargumbira at gmail.com>:
>>> Hi Akbar,
>>>> The most flexible installation tool that I know is probably python pip.
>>>> pip can install software from a zip file, from git and from other
>>>> sources too.
>>>> I'd suggest you to have a look to pip implementation of the install
>>>> functionality, maybe there is some interesting for you.
>>> I just read pip code base. I think I can pick something from there for
>>> downloading the resources. But the problem I have right now is to get only
>>> the metadata file from the repository. Or are you suggesting that when
>>> users add a repository connection, it also downloads the repository
>>> directly?
>> If you are working on the git repos you can probably fetch just one file
>> without cloning the whole repo, I did not test it but here are probably
>> some pointers:
>> http://stackoverflow.com/questions/2466735/how-to-checkout-only-one-file-from-git-repository
>> http://stackoverflow.com/questions/1125476/retrieve-a-single-file-from-a-repository
>>> On Mon, Jun 6, 2016 at 8:39 AM, Alessandro Pasotti <apasotti at gmail.com>
>>> wrote:
>>>> 2016-06-05 10:13 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net>:
>>>>> On 05-06-16 09:02, Akbar Gumbira wrote:
>>>>> > *Are you blocked on anything?*
>>>>> > ... In Github or Bitbucket they provide a direct link to
>>>>> > the raw file. But I think I should look at more general approach
>>>>> without
>>>>> > manipulating the URL depending on the host. If you have some input, I
>>>>> > would be happy to assess it.
>>>>> Thanks Akbar,
>>>>> I did some googling:
>>>>> http://stackoverflow.com/questions/14405782/git-fetch-single-file-from-remote-repository-programatically
>>>>> If you really want to keep it git, it looks like a shallow clone/copy
>>>>> is
>>>>> the only way? That post also talks about some undocumented feature, but
>>>>> I would not depend on that?
>>>>> Personally I would be ok when both Github and Gitlab/Gog would work (as
>>>>> both a closed source and open source member of the git-web-world)...
>>>>> Or: a script running somewhere on our server, (shallow) cloning all
>>>>> registred repositories periodically, and making just the metadata.txt
>>>>> files available via http/webserver? (maybe giving us some time to check
>>>>> the repo's on structure and (malicious?) content?
>>>>> Or else: a django app for the metadata...
>>>>> Regards,
>>>>> Richard
>>>> Hi Akbar,
>>>> sources too.
>>>> Alessandro Pasotti
>>>> w3: www.itopen.it
>>> *Akbar Gumbira *
>>> *www.akbargumbira.com <http://www.akbargumbira.com>*
>> Alessandro Pasotti
>> w3: www.itopen.it
> *Akbar Gumbira *
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160608/1cbfb861/attachment.html>
