[Qgis-developer] Build issue on Ubuntu 16.04 xenial with release-2_14 : crssync target failed
kimaidou
kimaidou at gmail.com
Wed Jun 8 05:17:56 PDT 2016
Yves, thanks for your answer
It appears I had 2 gdal installed :
one by qgis from qgis.org repository ( 1.11) which corresponds to
/usr/lib/libgdal.so
and one installed via apt-get install gdal-bin from repositories (2.1)
which corresponds to : /usr/local/lib/libgdal.so
So I changed GDAL lib directory and gdal-config path in ccmake, and run the
build again. It should do the trick
I will report back if this solves the issue I had
2016-06-08 14:09 GMT+02:00 Yves Jacolin <yjacolin at free.fr>:
> On Wednesday, June 08, 2016 13:49:53 kimaidou wrote:
> > Hi Bas,
> > Thanks for your answer.
> > It appears I built gdal on year ago to check GeoJson write capabilities
> in
> > QGIS.
> > Now, I have indeed just upgraded to last Ubuntu xenial, and I am trying
> to
> > get rid of old GDAL build and reinstall GDAL from repositories. So I
> > removed all symlinks made earlier today, I remove old Gdal build, remove
> > all lines concerning GDAL in /etc/ld.so.conf.d/. I ran ldconfig
> > Then uninstalled qgis and gdal-bin + libgdal and others, restarted my
> > computer
> > It still does not work.
> > mdouchin at mdouchin-Lenovo-U41-70:~$ ldd /usr/local/bin/gdalinfo | grep
> "not
> > found"
> > libnetcdf.so.7 => not found
> > libgif.so.4 => not found
> > I will do some more googling....
> If you install Gdal from package, why do you have such path to your gdal:
> How did you clean up gdal build? "make clean" don't remove gdal
> installation,
> you should remove the directory by hand.
> Y.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160608/816f6fb5/attachment.html>
