[Qgis-developer] Build issue on Ubuntu 16.04 xenial with release-2_14 : crssync target failed
kimaidou kimaidou at gmail.com
Wed Jun 8 05:47:29 PDT 2016
Hi all,
Setting the compilation variables via ccmake to point to libgdal 1.11.3
worked like a charm. QGIS 2.14 has successfully been built against gdal
1.11.3
Bas, you are right, I inverted them in my previous email. Here are the vars
used in ccmake to build QGIS successfully on my machine
GDAL_CONFIG                      /usr/bin/gdal-config
GDAL_INCLUDE_DIR                 /usr/include/gda
GDAL_LIBRARY                     /usr/lib/libgdal.so
Thanks again, both Bas and Yves, for you kind help
Cheers
Michaƫl
2016-06-08 14:36 GMT+02:00 Bas Couwenberg <sebastic at xs4all.nl>:
> On 2016-06-08 14:17, kimaidou wrote:
>> It appears I had 2 gdal installed :
>> one by qgis from qgis.org repository ( 1.11) which corresponds to
>> /usr/lib/libgdal.so
>> and one installed via apt-get install gdal-bin from repositories (2.1)
>> which corresponds to : /usr/local/lib/libgdal.so
> You got this the wrong way around, the package gdal is installed in
> /usr/lib, you custom build in /usr/local/lib.
> The /usr/local hierarchy is reserverd for the local administrator, /usr
> for the system.
> Kind Regards,
> Bas
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160608/9ec3b12a/attachment-0001.html>
