[Qgis-developer] QGIS Server performance deterioration
René-Luc Dhont
rldhont at gmail.com
Wed Jun 8 08:50:06 PDT 2016
Hi Devs,
I found which object is connected to QgsMapLayerRegistry through
layerWasAdded slot in QGIS Server, and it's QgsEditorWidgetRegistry !
The method mapLayerAdded is apply to the layer added:
void QgsEditorWidgetRegistry::mapLayerAdded( QgsMapLayer* mapLayer )
QgsVectorLayer* vl = qobject_cast<QgsVectorLayer*>( mapLayer );
if ( vl )
connect( vl, SIGNAL( readCustomSymbology( const QDomElement&,
QString& ) ), this, SLOT( readSymbology( const QDomElement&, QString& ) ) );
connect( vl, SIGNAL( writeCustomSymbology( QDomElement&,
QDomDocument&, QString& ) ), this, SLOT( writeSymbology( QDomElement&,
QDomDocument&, QString& ) ) );
Could a method call `mapLayerWillBeRemoved` be added ?
Le 07/06/2016 15:58, René-Luc Dhont a écrit :
> Hi devs,
> David Marteau, our colleague in 3Liz, has found some serious
> deteriorations of performance in QGIS Server.
> The first one concerne QgsExpressionContext which is not clean up in
> QgsServer::handleRequest
> Each call to QgsMapLayer::draw add items to QgsExpressionContext scope.
> The scope is not cleaned between request and thus the scope list to
> grow indefinitely.
> Having the list growing indefinitely deteriorate seriously
> performances in the long run. It also increase the memory footprint
> but in a less noticiable way.
> This behavior has been checked by monitoring reponse time of several
> ten of thousand identical requests during server long runs.
> This has been fixed in master and in LTR:
> https://github.com/qgis/QGIS/commit/5c3aa51e80887de6ff76682a42814041bb32cd5b
> https://github.com/qgis/QGIS/commit/50181eee00709e3f7e29b2b53282f28bdedfe265
> Now we encounter an other issue with deteriorationof performance in
> QGIS Server.
> This issue is due to the slot 'layerWasAdded' in QgsMapLayerRegistry.
> The duration of the emit layerWasAdded grows with the number of
> drawing. Do you know what it is done when 'layerWasAdded' is emitted ?
> Regards,
> René-Luc D'Hont
> 3Liz
