[Qgis-developer] What is the name for "pyspatialite" package in fedora 19?
童言 tongyan.cherish at 139.com
Wed Jun 8 20:47:51 PDT 2016
Thank you very much! I have solved this problem!-------------------------------------------------------------------------------Have you tried the instructions from the INSTALL file, it documents the
build procedure for Fedora too?
 https://github.com/qgis/QGIS/blob/master/INSTALL#L366
If you look through the CMake options, you'll find WITH_PYSPATIALITE
which you need to enable to have the embedded copy built along with the
rest of QGIS.
Kind Regards,
Bas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160609/547bdaf7/attachment.html>
