[Qgis-developer] New latlontools plugin
Matthias Kuhn matthias at opengis.ch
Fri Jun 10 01:26:07 PDT 2016
Is this (partially) related to this?
https://github.com/qgis/qgis3.0_api/issues/12
Matthias
On 06/10/2016 10:18 AM, Régis Haubourg wrote:
> Hi Calvin,
> you made a great comparing existing tools for coordinate handling. I
> was annoyed too with that mess. Could you make a feature request in
> hub.qgis.org <http://hub.qgis.org> asking for more rational in core
> QGIS ? I imagine that we could just have some tweaking of current
> coordinate widget so that it can have different formatting options,
> and have all addintional tools being merged to only one, handling all
> use cases.  making one more plugin is the right short term option to
> meet your actual need (plugins are great for that). Toavoiding too
> much efforts in maitaining those plugins, and also avoid plugin
> clutering, a feature request is the right thing to do :)
> Cheers
> Régis
> 2016-06-09 21:48 GMT+02:00 C Hamilton <adenaculture at gmail.com
> <mailto:adenaculture at gmail.com>>:
>     I just uploaded my latlontools plugin to the QGIS plugin site. I
>     know it is going to need some explanation as it duplicates some
>     existing functionality, but it was born out of frustration with
>     the existing plugins. Let me clarify that I am not saying there is
>     anything wrong with how these plugins work. They may be perfectly
>     suited for the needs of their users, but my work flow was such
>     that they did not satisfy my needs and even the time I spent in
>     writing the plugin was well worth the time I saved later with my
>     work flow. LatLonTools is designed to work in conjunction with
>     Google Maps and other on-line mapping.
>     The plugins that LatLonTools has the most similarity with are
>     Coordinate Capture, Copy_Coords, and ZoomToCoordinates, and Zoom
>     to Point.
>     The reason I wrote LatLonTools was because I was looking at
>     archaeological sites in Lidar hill shade and was comparing what I
>     was viewing in QGIS with imagery in Google Map, Google Earth, and
>     some other mapping tools. I was also working with coordinates in
>     Wikipedia. All of these represent coordinates as geographic
>     latitude and longitudes either in decimal or DMS notation. They
>     all specify latitude followed by longitude usually with a comma
>     separator. LatLonTools uses latitude and longitude coordinates no
>     matter what the CRS of the QGIS project is - hence the name
>     LatLonTools. It was also important to be able to copy the
>     coordinates verbatim usually in the format "latitude, longitude"
>     with slight variations and paste them into my plugin in one text
>     field (not two) and zoom to that point. Conversely I wanted a
>     single click in QGIS to copy a coordinate that I could paste in
>     Google Maps or Google Earth and zoom to that point. For my use
>     this is the problem with the existing plugins:
>     Zoom to Point:
>     1. Does not support DMS coordinates.
>     2. Has separate text fields for entering coordinates.
>     3. Requires coordinates in the CRS of the QGIS project and this
>     may not be in degrees.
>     Zoom to Coordinates
>     4. Not dockable.
>     Coordinate Capture
>     Although I have listed this one, it really doesn't compare to
>     LatLonTools because LatLonTools only captures to the clipboard so
>     I am going to rule it out as a similar plugin.
>     1. Does not support DMS notation.
>     2. Can capture the coordinate to the clipboard but it is in the
>     format of  "Longitude, Latitude, Native CRS X, Native CRS Y" and
>     is not suitable to paste into Google Earth.
>     3. Even if you could click on the Capture button to get the right
>     coordinate you still have an extra click. With LatLonTools you
>     only need to click on the map and the coordinate is captured to
>     the clipboard in the right format for Google Earth.
>     Copy_Coords
>     1. Copies the coordinate in the format of "Longitude, Latitude" or
>     in the native CRS of "X, Y". This is not suitable to paste into
>     Google Earth.
>     2. Does not support DMS notation.
>     3. Does not give any indication to the user that the coordinate
>     was captured.
>     4. If the CRS is anything other than 4326 the output will not be
>     in degrees.
>     The major difference with LatLonTools is that it assumes degrees
>     as input and output no matter what the project CRS is and it
>     formats them in the order of on-line maps. Here is what
>     LatLonTools offers:
>     1. Has a single string input of "Latitude, Longitude". Actually,
>     the delimiter can be one or more comma, space, tab, semicolon, or
>     colon. Note that with a tab you can paste the coordinates into a
>     spread sheet in adjacent columns.
>     2. Supports DMS on input and output.
>     3. Single click coordinate capture in the proper format for
>     on-line maps.
>     4. Displays the coordinate in the lower left as the mouse moves
>     over the map.
>     5. In settings you can configure the capture format as decimal
>     degrees, DMS, DDMMSS or even the Native CRS, but will be in the
>     order Y,X or Latitude, Longitude.
>     6. In settings you can specify the delimiter between the two
>     coordinates as a comma, tab, space or anything you want.
>     7. Two tools in one plugin.
>     8. I may add an additional capability to paste in a block of
>     coordinates that create a list to click on and view.
>     9. Input is in a dockable window which I prefer to a popup window.
>     For anyone who uses QGIS in conjunction with Google Earth, Google
>     Maps or the like are really going to appreciate LatLonTools.
>     My goal was not to duplicate the work flow of the similar plugins,
>     but to optimize my work flow, but there are several easy
>     modifications that I could make in the "Settings" so that it could
>     operate in the same manner as 3 of the plugins. I would only do
>     this if the community wanted it, because I would never work with
>     coordinates the way they do. LatLonTools will only have a single
>     string as input so if the other plugins want two input text boxes
>     then there is no overlap. In the "Settings" it would be easy to
>     support coordinates is in the order of "X, Y" like the other
>     plugins for those who need that ordering. And in the settings I
>     could also provide an option for Native CRS input if others were
>     interested.
>     I know this has been an incredibly long e-mail, but wanted to lay
>     out the reasons for this plugin and am requesting that you
>     consider adding it to the plugin repository. The plugin will
>     likely expand with a bulk zoom to point feature.
>     Thanks,
>     Calvin
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Régis Haubourg
> Attention, changement d'adresse mail!
> Mon adresse principale devient désormais regis.haubourg at gmail.com
> <http://gmail.com>
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160610/9d6a763e/attachment-0001.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160610/9d6a763e/attachment-0001.sig>
