[Qgis-developer] The first column in the attribute table
Neumann, Andreas
a.neumann at carto.net
Thu Jun 16 00:18:52 PDT 2016
Hi Matthias,
If there are no negative side effects - I'd like to see the same
behaviour like in spreadsheets - an always ascending list, starting from
1 - regardless of the order of the rows.
Would this be a lot of work to change this?
Andreas
On 2016-06-16 09:06, Matthias Kuhn wrote:
> Hi Andreas,
> I always thought that they are the feature ID. But not even that, often
> they are "feature id - 1", but that's not guaranteed at all.
> We could make it match the feature id. Or the current index in the table
> like you propose.
> Matthias
> On 06/16/2016 08:56 AM, Neumann, Andreas wrote:
>> Hi,
>> I'd like to discuss an issue in the attribute table.
>> There is this very first column (not stored in the provider) which lists
>> the features as they appear in the provider (by default, if not
>> re-ordered by the user). What are these values? Some internal ID not
>> present in the data? Or some internal ID from the qt table widget?
>> I am just wondering, because regarding this first column, QGIS behaves
>> different from Spreadsheets.
>> When you reorder the table in QGIS, this very first column becomes "out
>> of order" - spreadsheets always display 1 to xxx - nicely ordered -
>> regardless of the sort order. Could QGIS be aligned to the behaviour of
>> spreadsheets or is there a particular reason not do so? I think, from a
>> users perspective, because these numbers are not present in the data,
>> that it would be more useful if they always stay ordered from 1 to xxx
>> or 0 to xxx, regardless of sorting.
>> Thank you for your feedback.
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160616/e3497477/attachment.html>
