[Qgis-developer] GRASS Plugin Delete vector issue in windows
roy roy
royroge at outlook.com
Sat Jun 18 00:42:02 PDT 2016
Il 18/05/2016 15:03, Radim Blazek ha scritto:
> I fixed that today in bbaef371. The code which should close the map
> was commented, which resulted in keeping the file open and
> impossibility to delete the vector on Windows. Please test with the
> next build.
> There was a comment about possible dead-lock, so please pay attention
> to possible freeze when a GRASS vector is deleted and fill a new bug
> in such case. I hope it is OK however.
> Radim
I found GRASS GIS Plugin back on track on QGIS 2.15-dev and just tested
to load and
delete some vector files, the layer is deleted with no leftover so
everithing seems good now,
thank you, Roy.
