[Qgis-developer] many R plots output in Processing
René-Luc Dhont
rldhont at gmail.com
Mon Jun 20 02:28:23 PDT 2016
Hi Matteo,
R scripts can produce only 1 plots with showplots parameter.
If you want many plots as output you have to draw all in 1.
There is an example here
https://github.com/qgis/QGIS-Processing/tree/master/rscripts made by
JEANDENANS Laura.
Regards,
René-Luc
Le 20/06/2016 11:05, matteo a écrit :
> Hi all (again),
> I'm writing some R scripts that produce some plots.
> If I'm not wrong (else I am doing something wrong) it seems that it is
> not possible to display many outputs, that is the only the last plot
> is shown, overwriting the previous(es) ones
> I tried the following:
> ##Vector processing=group
> ##showplots
> ##showplots
> and
> ##showplots
> ##showplots2
> but always the same result..
> Am I missing something?
> Thanks to all
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
