[Qgis-developer] custom charts?
Neumann, Andreas
a.neumann at carto.net
Fri Jun 24 05:25:38 PDT 2016
Pretty cool - so we can deliver script-generated SVG code instead of a
filename? Nice!
Care to do a blog post with some example? This sounds quite exciting to
me.
Andreas
On 2016-06-24 14:12, Raymond Nijssen wrote:
> Hi Hugo,
> It works! Thanks a lot!!
> This is exactly what i was looking for, but somehow could not find.
> Here is a little example with some fake svg's:
> http://terglobo.nl/downloads/example.png
> Now I will script generating svg based on real data.
> Regards,
> Raymond
> On 23-06-16 09:02, Hugo Mercier wrote: On 22/06/2016 19:06, Richard Duivenvoorde wrote: On 22-06-16 14:39, Hugo Mercier wrote: Hi Raymond, - Add a text field to my feature layer containig svg, and somehow make
> qgis display that on my map;
> This should work, no ?
Are you sure? This would mean that the value(!) of an attribute would
contain the actual svg (code, not filename).
Any example on how to use that with styling then?
Hmmm exact, I don't think you can include the content (I tried to
include a data url but it does not work).
> - Add a text field to my feature layer containig a path to a png (or
> svg), and somehow make qgis display that on my map.
> An SVG marker with the file name defined as an expression ?
Same here, while we managed to get for example colors dynamic, we could
not find a way (yet) to set the marker-svg once filename is retrieved
from an attribute...
Happy to get an example or pointers :-)
with an SVG-marker the filename can be "data-defined", so you can for
instance use an expression like '/xxx/mymarker_' || id || '.svg'
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160624/a56d19bb/attachment.html>
