[Qgis-developer] custom charts?
Hugo Mercier hugo.mercier at oslandia.com
Fri Jun 24 05:59:22 PDT 2016
Actually, we already have a "template" concept in SVG, if you look at
the SVG shipped with QGIS, they have things like fill="param(fill)"
allowing to have the filling color as a user parameter.
That could be easily extended to also support feature's attributes and
expressions.
On 24/06/2016 14:45, Raymond Nijssen wrote:
> Hugo,
> That would be way cooler!
> For now, I just write generated svg files to a temp directory and add
> links to them to every feature.
> Strings might get long though. Here is for example the code from my
> dummy image (1.4kb):
> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> <!-- Created with Inkscape (http://www.inkscape.org/) -->
> <svg
>    xmlns:dc="http://purl.org/dc/elements/1.1/"
>    xmlns:cc="http://creativecommons.org/ns#"
>    xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
>    xmlns:svg="http://www.w3.org/2000/svg"
>    xmlns="http://www.w3.org/2000/svg"
>    version="1.1"
>    width="32"
>    height="32"
>    id="svg2985">
>   <defs
>      id="defs2987" />
>   <metadata
>      id="metadata2990">
>     <rdf:RDF>
>       <cc:Work
>          rdf:about="">
>         <dc:format>image/svg+xml</dc:format>
>         <dc:type
>            rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
>         <dc:title></dc:title>
>       </cc:Work>
>     </rdf:RDF>
>   </metadata>
>   <g
>      id="layer1">
>     <rect
>        width="32"
>        height="32"
>        ry="5.1795878"
>        x="0"
>        y="0"
>        id="rect2993"
>        style="fill:#efefef;fill-opacity:1;stroke:none" />
>     <path
>        d="m 3.2204932,9.8354288 c 0,0 2.1492989,4.3642312
> 5.9021879,4.1948682 2.6857939,-0.121208 2.4849709,-3.285023
> 5.3970119,-3.017097 3.079402,0.283325 2.518907,6.965981
> 6.783374,7.088215 4.047473,0.116014 6.797316,8.50238 6.797316,8.50238"
>        id="path3763"
> style="fill:none;stroke:#a32800;stroke-width:1.60000002;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-opacity:1;stroke-dasharray:none"
>   </g>
> </svg>
> On 24-06-16 14:34, Hugo Mercier wrote:
>> It would be also cool to be able to directly use a string as image
>> content for a marker (rather than just for the filename).
>> That should be quite easy to do.
>> On 24/06/2016 14:28, Nathan Woodrow wrote:
>>> Raymond,
>>> Code generated SVGs is a pretty cool idea.  Would be super keen to see
>>> that once you have something!
>>> On Fri, Jun 24, 2016 at 10:25 PM, Neumann, Andreas <a.neumann at carto.net
>>> <mailto:a.neumann at carto.net>> wrote:
>>>     Pretty cool - so we can deliver script-generated SVG code instead of
>>>     a filename? Nice!
>>>     Care to do a blog post with some example? This sounds quite exciting
>>>     to me.
>>>     Andreas
>>>     On 2016-06-24 14:12, Raymond Nijssen wrote:
>>>>     Hi Hugo,
>>>>     It works! Thanks a lot!!
>>>>     This is exactly what i was looking for, but somehow could not find.
>>>>     Here is a little example with some fake svg's:
>>>>     http://terglobo.nl/downloads/example.png
>>>>     Now I will script generating svg based on real data.
>>>>     Regards,
>>>>     Raymond
>>>>     On 23-06-16 09:02, Hugo Mercier wrote:
>>>>>     On 22/06/2016 19:06, Richard Duivenvoorde wrote:
>>>>>>     On 22-06-16 14:39, Hugo Mercier wrote:
>>>>>>>     Hi Raymond,
>>>>>>>>     - Add a text field to my feature layer containig svg, and
>>>>>>>>     somehow make
>>>>>>>>     qgis display that on my map;
>>>>>>>     This should work, no ?
>>>>>>     Are you sure? This would mean that the value(!) of an attribute
>>>>>>     would
>>>>>>     contain the actual svg (code, not filename).
>>>>>>     Any example on how to use that with styling then?
>>>>>     Hmmm exact, I don't think you can include the content (I tried to
>>>>>     include a data url but it does not work).
>>>>>>>>     - Add a text field to my feature layer containig a path to a
>>>>>>>>     png (or
>>>>>>>>     svg), and somehow make qgis display that on my map.
>>>>>>>     An SVG marker with the file name defined as an expression ?
>>>>>>     Same here, while we managed to get for example colors dynamic,
>>>>>>     we could
>>>>>>     not find a way (yet) to set the marker-svg once filename is
>>>>>>     retrieved
>>>>>>     from an attribute...
>>>>>>     Happy to get an example or pointers :-)
>>>>>     with an SVG-marker the filename can be "data-defined", so you can for
>>>>>     instance use an expression like '/xxx/mymarker_' || id || '.svg'
>>>>>     _______________________________________________
>>>>>     Qgis-developer mailing list
>>>>>     Qgis-developer at lists.osgeo.org
>>>>>     <mailto:Qgis-developer at lists.osgeo.org>
>>>>>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
