[Qgis-developer] create geometry less memory layer
Neumann, Andreas
a.neumann at carto.net
Mon Mar 7 05:14:15 PST 2016
Hi Matteo,
Which version of QGIS?
Starting from 2.14 you can uncheck the checkbox "Geometry tpye and CRS"
and the result will be a scratch layer without geometry. After creation,
you can add additional attribute columns.
Hope this helps,
Andreas
On 2016-03-07 12:17, matteo wrote:
> Hi all,
> a very simple question (which I cannot find an answer). Is it possible
> to create a geometry less memory layer?
> In both cookbook there are all the 'geometric' options available for the
> memory provider (Point, line, polygon and their multi part options) but
> not a 'table' option.
> Thanks
> Best,
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160307/3c2d1060/attachment.html>
