[Qgis-developer] create geometry less memory layer
Hugo Mercier
hugo.mercier at oslandia.com
Mon Mar 7 06:03:31 PST 2016
On 07/03/2016 14:59, matteo wrote:
> Hi Andreas,
>> Hi Matteo,
>> Which version of QGIS?
> QGIS 2.15 dev
>> Starting from 2.14 you can uncheck the checkbox "Geometry tpye and CRS"
>> and the result will be a scratch layer without geometry. After creation,
>> you can add additional attribute columns.
> awesome! I didn't know that!
> Is there also a way with python trough QgsVectorLayer to do that?
Use "none" as geometry type:
QgsVectorLayer("none", "layer", "memory")
> Thanks Andreas
> Best
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
