[Qgis-developer] fatal error: testqgscomposertablev2.moc
Matthias Kuhn matthias at opengis.ch
Fri Mar 11 02:42:02 PST 2016
Hi René,
this is a cmake 3.2 issue. If you are able to up- or downgrade cmake
(they even offer a portable version on their homepage[1]) that will
solve the issue.
For a quick workaround you can temporarily rename some tests as can be
seen here [2].
Cheers
[1] https://cmake.org/
[2] https://github.com/qgis/QGIS/pull/2679/files
On 03/11/2016 11:37 AM, René-Luc Dhont wrote:
> Hi dev,
> I just started a clean release 2.14 build and I optains this error :
> Do I have miss somethings ?
> Regards,
> René-Luc
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160311/933035be/attachment.sig>
