[Qgis-developer] Processing tests
Anita Graser anitagraser at gmx.at
Sun Mar 13 03:32:38 PDT 2016
Hi Matthias,
How can I check whether my test works before I create a PR?
Thanks and best wishes,
Anita
On Tue, Feb 23, 2016 at 12:58 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> You have probably noticed that recently some tests for processing have
> been included.
> They run geo-algorithms and check if their result matches with what is
> expected.
> It is very easy to expand this suite. Test definitions are written in
> the form of yaml. Templates for this definitions can be created from the
> processing history. There are some possibilities to fine-tune the
> comparison (e.g. skip fields, allow values to be compared with an
> epsilon, match a result file with a series of regular expressions...)
> which have been added more recently. At the moment it runs tests for
> some qgis algorithms and gdal algorithms.
> If you have 5 minutes to spare today, please help and add a test!
> More information can be found in our blog [1] and the readme [2].
> Thanks a lot,
> Matthias
> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tests/README.md
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160313/bfaa2686/attachment.html>
