[Qgis-developer] Aggregates within expression engine
Neumann, Andreas
a.neumann at carto.net
Wed Mar 16 00:30:04 PDT 2016
Hi Paolo,
Thank you for your feedback.
Why do you think SQL aggregate syntax (e.g. as outlined at
http://www.postgresql.org/docs/9.5/interactive/functions-aggregate.html)
is a no-go? Can you explain this in detail? QGIS is much closer to a
database then it is to a spreadsheet - in fact for most serious QGIS
work you store your data in a SQL database.
It was my impression that QGIS tries to maintain expression syntax
compatible with SQL wherever possible. I think it would be a good thing.
The question is how we can specify grouping. I'd like to see support for
the following grouping mechanisms:
* whole record set
* given grouping field or expression
* current selection
* grouping based on relations (very important to my employer) - also
our initial trigger for funding this work
* current set of symbology rules or classes (not so important to me,
but maybe useful to some)
Andreas
On 2016-03-16 08:11, Paolo Cavallini wrote:
> Hi Nyall,
> Il 16/03/2016 07:17, Nyall Dawson ha scritto:
>> I'm also torn regarding the best syntax to use for aggregates within
>> expressions. I'm unsure if the traditional SQL "group by" clauses
>> would be a good fit within the existing QGIS expression syntax (eg
>> "sum("some_field") group by "some_other_field"). To me it doesn't fit
>> with the existing functional approach that the expressions take. But
>> on the other hand, trying to implement this as functions would result
>> in some very clumsy expressions: "aggregate('sum', "some_field",
>> "some_other_field")" or "sum("some_field", "some_other_field") ". Has
>> anyone got any other ideas for syntax which would be a good fit?
> Good news, thanks for sharing.
> IMHO having a syntax that is easy to use for the average user is a
> crucial point. I think using SQL is a no go. Why not using the
> spreadsheet syntax? Not that I find it particularly attractive, but at
> least everybody is more or less familiar with it.
> All the best.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160316/4d7adc8e/attachment.html>
