[Qgis-developer] Aggregates within expression engine
Nyall Dawson
nyall.dawson at gmail.com
Wed Mar 16 01:21:21 PDT 2016
On 16 March 2016 at 19:15, Hugo Mercier <hugo.mercier at oslandia.com> wrote:
> Hi,
> Just for me to understand: why not considering improving a bit the
> virtual layers ?
> There is already a support for user defined aggregate functions. Caching
> of the computed aggregate is already done by the engine (I guess). And
> we could add some functions to restrict the query to the selected
> features of a layer or deal with relations ...
> And using something like the "query builder" found in db manager (and
> inspired by mapinfo), it may ease to deal with the SQL syntax ...
I think the use case is quite different. Having aggregates in
expressions is useful for things like embedding the values in
composers and atlas prints, or in data defined overrides.
Nyall
> On 16/03/2016 08:30, Neumann, Andreas wrote:
>> Hi Paolo,
>> Thank you for your feedback.
>> Why do you think SQL aggregate syntax (e.g. as outlined
>> at http://www.postgresql.org/docs/9.5/interactive/functions-aggregate.html)
>> is a no-go? Can you explain this in detail? QGIS is much closer to a
>> database then it is to a spreadsheet - in fact for most serious QGIS
>> work you store your data in a SQL database.
>> It was my impression that QGIS tries to maintain expression syntax
>> compatible with SQL wherever possible. I think it would be a good thing.
>> The question is how we can specify grouping. I'd like to see support for
>> the following grouping mechanisms:
>> * whole record set
>> * given grouping field or expression
>> * current selection
>> * grouping based on relations (very important to my employer) - also
>> our initial trigger for funding this work
>> * current set of symbology rules or classes (not so important to me,
>> but maybe useful to some)
>> Andreas
>> On 2016-03-16 08:11, Paolo Cavallini wrote:
>>> Hi Nyall,
>>> Il 16/03/2016 07:17, Nyall Dawson ha scritto:
>>>> I'm also torn regarding the best syntax to use for aggregates within
>>>> expressions. I'm unsure if the traditional SQL "group by" clauses
>>>> would be a good fit within the existing QGIS expression syntax (eg
>>>> "sum("some_field") group by "some_other_field"). To me it doesn't fit
>>>> with the existing functional approach that the expressions take. But
>>>> on the other hand, trying to implement this as functions would result
>>>> in some very clumsy expressions: "aggregate('sum', "some_field",
>>>> "some_other_field")" or "sum("some_field", "some_other_field") ". Has
>>>> anyone got any other ideas for syntax which would be a good fit?
>>> Good news, thanks for sharing.
>>> IMHO having a syntax that is easy to use for the average user is a
>>> crucial point. I think using SQL is a no go. Why not using the
>>> spreadsheet syntax? Not that I find it particularly attractive, but at
>>> least everybody is more or less familiar with it.
>>> All the best.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
