[Qgis-developer] Dockers for QGIS
Sandro Santilli
strk at keybit.net
Sun Mar 20 02:56:51 PDT 2016
On Sat, Mar 19, 2016 at 09:46:28AM +0100, Paolo Cavallini wrote:
> I'm using several versions of QGIS:
> * 2.8 for production, especially on the server side
> * 2.14 for normal work
> * dev for experimenting and early qt5-py3 testing.
> I do not want to mess up my clean Debian, so I only use packages.
> As a possible solution to my problem, I'm trying out Tim dockers for QGIS:
> http://kartoza.com/qgis-desktop-in-docker/
> but I have not much success. Is anyone using it?
> Are there simpler, yet clean, alternatives?
Personally I use qgis from the build dir, but I understand it only
works when you compile it yourself, and still shares the home
directory for plugins (which may or may not be wanted).
--strk;
