[Qgis-developer] Dockers for QGIS
Tim Sutton
tim at kartoza.com
Tue Mar 22 14:41:31 PDT 2016
Hi
On Sun, Mar 20, 2016 at 4:47 PM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Il 20/03/2016 10:17, Tim Sutton ha scritto:
> > I mainly had bad experiences when trying to mix packages and hand build
> > QGIS on the same system. Since I don’t use packages I have every version
> > of QGIS installed for the last 6 or so releases in a pattern like this
> > /usr/local/qgis-<version>
> > I have little launcher scripts and .desktop files so that you can simply
> > launch whichever version you want from gnome (or whatever DE you
> > prefer). This all works seamlessly without any issue. I also have docker
> > launchers set up in a similar way. Although I am a huge fan of docker, I
> > actually think building multiple binaries into different prefixes gives
> > you a better experience and would be my recommended approach if a user
> > is able to compile themselves.
> OK, I'll follow your recommendations then.
> > I’ll make a little repo with my start
> > scripts and .desktop files if that is useful to anyone (you just need to
> > ensure you use the same INSTALL_PREFIX convention I do.
> Please do share it. A very short howto on what your install approach is
> will be useful.
Will do when I get back to my desktop PC with all my scripts on it.
Regards
Tim
> All the best, and thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Tim Sutton
Visit http://kartoza.com to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160322/2a3cb8bb/attachment-0001.html>
