[Qgis-developer] Issue with Shapefile creation algorithm
Jean-Christophe Bastin jcbastin at thelis.be
Thu Mar 31 06:43:04 PDT 2016
Hi QGIS Developers,
I didn't had other answer about my thread.
Nobody here can tell me if there is any tool that can analyse my
shapefile to know exactly what's wrong with it ?
Many thanks.
Regards,
JCB
Le 21/03/2016 10:36, Jean-Christophe Bastin a écrit :
> I just found the "checking tool" of geometry in the Vector menu of QGIS.
> It tells me "Unknown geometry type 0", "The geometry has 1 error".
> But in my algorithm, I put 5 as type, as explained in specifications.
> From where comes this 0 ? ...
> Regards,
> JCB
> Le 21/03/2016 10:16, Jean-Christophe Bastin a écrit :
>> Thank you for the answer Maximilian
>> Indeed, the Python console shows me None for some geometries.
>> Do you know any tool that can analyse what's wrong with the shape ?
>> Maybe something that can translate the shp file into a readable
>> format according to specifications from
>> https://www.esri.com/library/whitepapers/pdfs/shapefile.pdf ?
>> Regards,
>> JCB
>> Le 18/03/2016 14:54, Maximilian Krambach a écrit :
>>> For the one shape I get 7 valid and one "none" geometries (the last
>>> feature).
>>> for the other shape, just a "none" geometry
>>> It seems that some "end of file" is off.
>>> Function I used with the python console in QGIS:
>>> layer = iface.activeLayer()
>>> for feature in layer.getFeatures():
>>>      print feature
>>>      print feature.geometry()
>>> print layer.featureCount()
>>> Am 18.03.2016 um 14:18 schrieb Jean-Christophe Bastin:
>>>> Hi QGIS Developers :-)
>>>> I asked some help on QGIS support, but they told me that I don't
>>>> ask my
>>>> question at the right place, and that I should go througth developers
>>>> email list.
>>>> That's why I'm here. So let me explain what's going on.
>>>> I developped an application with a class able to read data from an
>>>> Oracle database with MapXtreme (MapInfo), and convert them in
>>>> Shapefile.
>>>> This class follows the ESRI specifications from here :
>>>> You can find in attach 2 samples that I tried to open in QGIS :
>>>> - 4480___S12_060_4 : there is only one polygon, but it is not
>>>> displayed
>>>> on the map
>>>> - 4480___327550 : there are 8 polygons in this one, and all of them
>>>> are
>>>> well displayed
>>>> The strange thing is that the polygon from "4480___S12_060_4" is
>>>> common
>>>> with "4480___327550", but in one case it is not shown, and in the
>>>> other
>>>> case it is shown.
>>>> I have no problem when I open these files with MapInfo.
>>>> I don't have ArcMap to check on this side.
>>>> The support told me they were not able to open my files with SAGA,
>>>> but I
>>>> downloaded SAGA GIS 2.2.3 and was able to open the file without any
>>>> issue...
>>>> According to QGIS support, it looks like an issue in my creation
>>>> algorithm, but I really don't see what's wrong, it seems to follow
>>>> well
>>>> the ESRI specifications.
>>>> I'm not a "GIS expert", so maybe some of you could help me to discover
>>>> what's wrong.
>>>> Or if you have any GIS tool that can tell me what's not correct in my
>>>> shapefile, it could really help me.
>>>> You can find in attachment the source code of my class in VB.Net.
>>>> Many thanks !
>>>> Regards,
>>>> JCB
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
