[Qgis-developer] Unable to build QGIS-Website with Paver
Richard Duivenvoorde
rdmailings at duif.net
Mon May 2 06:21:45 PDT 2016
Hi H,
I do not think you will be able to create pdf's on Windows with Paver.
Never really tried, but for pdf generation (also on Linux) you need A
LOT of dependencies: Latex stuff, special fonts etc etc
IF you want to create pdf's I think you either have to try the docker
way (because then the images you download from QGIS will contain ALL you
need), or you to find a Debian machine to work on...
Sorry,
Richard
On 02-05-16 08:09, DelazJ wrote:
> Hi,
> Richard, thanks for your answer!
> Afaics, I have only one python installed, through osgeo4w. I tried
> setting the pythonhome as "C:\[PythonDir]\DLLs" and then as
> "C:\[PythonDir]" without success.
> I then tried docker but to be honest I find it not that straightforward
> (at least on Windows) and it seems that it requires more knowledge on
> virtualisation matters (what i lack). So I gave up!
> I then come back to paver set osgeo4w directory as path environment
> variable for the user and it works like a charm! i can build docs and
> website ... don't know which changes really work but now it works (won't
> check further :) )
> I'd like to fix some issues in docs pdf version but when i generate doc,
> I can't find a local pdf. The one i get is linked to the official online
> one.
> Any idea how I can build a pdf doc locally? Trying _paver pdf_ complains
> about missing gdbm and a pip install gdbm states:
> *could not find a version that satisfied the requirement gdbm (version: )
> No matching distribution found for gdbm*
> and internet is no more prolific
> Thanks for any other help..
> Harrissou
> 2016-04-27 16:56 GMT+02:00 Richard Duivenvoorde <rdmailings at duif.net
> <mailto:rdmailings at duif.net>>:
> Hi,
> Googling I found this
> https://github.com/pypa/virtualenv/issues/72
> and there they say:
> In case someone else is looking at this, make sure "C:\[PythonDir]\DLLs"
> is in your pythonpath environment variable, NOT your path variable.
> In your case maybe the problem is maybe two python installs? One normal
> one and one in osgeo4w?
> Another option would be to try the 'Docker'-way.
> I just build both docs and website (and translations) on a Windows 10
> machine, following the instructions from:
> https://github.com/qgis/QGIS-Website#building-the-website-using-docker
> Only change is that boot2docker is not 'depricated', and you should use
> this docker-product:
> https://www.docker.com/products/docker-toolbox
> let me know if you need further help.
> Regards,
> Richard
> On 20-04-16 20:25, DelazJ wrote:
> > Hi,
> > I'm tring to build QGIS-website with Paver
> <https://github.com/qgis/QGIS-Website#building-the-website-using-paver>
> > on Windows 10 and it fails in the earlier steps
> > I have easy_install installed (can find it in my
> > osgeo4w64/Apps/Python/Scripts folder, added to the PATH)
> > When I launch python bootstrap.py from my local repo folder, I get :
> > F:\SIG\GitHub\QGIS-Website> python bootstrap.py
> > PYTHONHOME is set. You *must* activate the virtualenv before using it
> > New python executable in virtualenv\Scripts\python.exe
> > Installing setuptools..............
> > Complete output from command
> > F:\SIG\GitHub\QGIS-W...v\Scripts\python.exe -c "#!python
> > \"\"\"Bootstra...sys.argv[1:])
> > " --always-copy -U setuptools:
> > Traceback (most recent call last):
> > File "<string>", line 278, in <module>
> > File "<string>", line 210, in main
> > File "<string>", line 132, in download_setuptools
> > File "C:\OSGeo4W64\apps\Python27\Lib\urllib2.py", line 94, in
> <module>
> > import httplib
> > File "C:\OSGeo4W64\apps\Python27\Lib\httplib.py", line 71, in
> <module>
> > import socket
> > File "C:\OSGeo4W64\apps\Python27\Lib\socket.py", line 47, in
> <module>
> > import _socket
> > ImportError: No module named _socket
> > ...Installing setuptools...done.
> > File "bootstrap.py", line 2601, in <module>
> > main()
> > File "bootstrap.py", line 981, in main
> > no_pip=options.no_pip)
> > File "bootstrap.py", line 1093, in create_environment
> > search_dirs=search_dirs, never_download=never_download)
> > File "bootstrap.py", line 613, in install_setuptools
> > File "bootstrap.py", line 585, in _install_req
> > cwd=cwd)
> > File "bootstrap.py", line 1059, in call_subprocess
> > % (cmd_desc, proc.returncode))
> > OSError: Command F:\SIG\GitHub\QGIS-W...v\Scripts\python.exe -c
> "#!python
> > " --always-copy -U setuptools failed with error code 1
> > Can someone explain what's wrong, please?
> > Thanks,
> > H.
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
