[Qgis-developer] Qt5 and Python 3
Matthias Kuhn
matthias at opengis.ch
Wed May 4 02:57:33 PDT 2016
On 05/04/2016 11:54 AM, Denis Rouzaud wrote:
> On 05/04/2016 11:00 AM, Matthias Kuhn wrote:
>> We could
>> * Switch to another API (sip.enableautoconversion(false), similar to
>> SIP API V1). Resulting in countless lines of code in plugins requiring
>> to be updated.
>> * Bump the minimum Qt version to 5.7 (and hope that PyQtNullVariant
>> will be fixed there, chances are good, see
>> https://www.riverbankcomputing.com/pipermail/pyqt/2016-April/037336.html).
> Is the discussion the only trace of this or is there a feature request open?
> Time frame is quite tight...
> https://wiki.qt.io/Qt_5.7_Release
It's a PyQt issue, not a Qt issue.
Discussion is here:
Matthias
