[Qgis-developer] Images and button in Qt Designer
Worth Lutz wal3 at mindspring.com
Fri May 6 05:30:31 PDT 2016
You have stumbled on a temporary solution.  If you open the resources in
QT Designer again, you may see the problem again. Running pyrcc4 will be
necessary.
*Worth Lutz*
On 5/6/2016 8:08 AM, matteo wrote:
> Hi Richard,
> thanks for also your support.. It seems that in some way the problem
> has been solved.
> For sure in all my attempts I mixed some files and other stuff.. So
> what seems working is:
> 1. when adding a new icon in Qt, I choose to load it from the existing
> resource file of the plugin. In the menu click on the arrow and ->
> Choose Resource
> 2. edit the resource and add the other icons (even in other folders,
> mines for examples are in plugins/plugin_root/icons/)
> 3. save the UI and run the compilation of the resources as suggest by
> Ginetto
> pyrcc4 -o resources.py resources.qrc
> now the plugin shows the icon in the pushbutton..
> I don't know how/what I did.. If I mixed some commands..
> For the moment it seems working.. (tried to add other icons, reload
> the plugin, make some changes in the dialog.py)
> So thanks to all the feedbacks.. (maybe it is worth to add this part
> in the cookbook?)
> Cheers
> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160506/c45fceb8/attachment.html>
