[Qgis-developer] QgsFeatureRequest::FilterFid and QgsFeatureRequest::FilterFids do not retrieve the same Feature
René-Luc Dhont
rldhont at gmail.com
Mon May 9 09:00:27 PDT 2016
Hi devs,
I have an issue in QGIS Server with features filtered by FeatureId. I
can reproduce the issue in Python console.
With a vector that has joined attributes and virtual attributes, the
QgsFeatureRequest::FilterFid retrieves a feature with all the attributes
values but just the layer fields.
With the same layer, the QgsFeatureRequest::FilterFids with 1 featureId
retrieves a feature with all the attributes values and fields.
You can test it in the Python console with that code wher `l` is the
vector layer
fr = QgsFeatureRequest().setFilterFid( 2
).setFlags(QgsFeatureRequest.NoFlags)
fit = l.getFeatures( fr )
for feat in fit:
len( feat.fields().toList() )
len( feat.attributes() )
fr = QgsFeatureRequest().setFilterFids( [2]
for feat in fit:
In the first case, the len will be different, in the second case it is
the same.
Does some one know how to fix it ?
Regards,
René-Luc
