[Qgis-developer] GEOS error Exception: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
Nyall Dawson nyall.dawson at gmail.com
Fri May 13 01:36:50 PDT 2016
On 13 May 2016 at 17:53, Janneke van Dijk <janneke.qgis at gmail.com> wrote:
> Dear list,
> Using QGIS 2.14.2 on Windows 7 I get the following error message when
> zooming out on a shapefile layer that has labels switched on:
> GEOS
> It seems to be an old bug (https://hub.qgis.org/issues/9375) that was fixed
> 2 years ago.
> It doesn't seem to cause any problems otherwise. Anyone else have this
> issue? Should I file a new bug report?
Hi Janneke,
Best thing to do is file an issue at http://hub.qgis.org/issues with a
copy of your data + sample project. If you do that this bug should be
easy for us to squash!
Thanks,
Nyall
> Regards,
> Janneke
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
